smartfreenas
May 25, 2026Aspirant
GS728TP v1 failed update
Can you tell me if it's possible to restore the GS728TP v1 after a failed update? The firmware was 6.0.1.14. I updated to the latest firmware 6.0.1.30 via SCC (Smart Control Center). SCC (Smart...
schumaku
May 26, 2026Guru - Experienced User
Instead of digging in the dark - connect the serial port pins on the switch motherboard. Pinout is similar on all Netgear devices
Accessing Bootloader via Putty on RBR50 | NETGEAR Communities
Alternate attempt is to connect from a computer in the 192.168.0.0/24 subnet, like 192.168.0.123/24 255.255.255.0, disconnect all switch ports from DHCP servers, and fire up a tftp application attemting to push the firmware image.
- StephenBMay 27, 2026Guru - Experienced User
FWI, the switch IP normally defaults to 192.168.0.239 when DHCP fails.
