XDRich
Feb 15, 2017Guide
STP Leak using Broadcast packet 01:80:c2:00:00:1c
Netgear Support, Please take note that the community and several customers have discovered a possible flaw in your STP implementation that causes CPU panic and circular broadcasts that disable sw...
- Jun 07, 2017
LarryV and to others,
Since a firmware fix is not yet available, the MAC ACL workaround can be used as described on the article below:
DaneA
NETGEAR Communtiy Team
LaurentMa
Feb 24, 2017NETGEAR Expert
Thank you XDRich, yes it helps.
We can reproduce the issue now. The offending packet is a multicast packet with MAC destination address of “01:80:c2:00:00:01c” that was generated by Ubiquiti’s new wifi AP software 3.7.37 release. The switch would react negatively as you’d reported when it received such packet, but there is no long term impact to the switch.
We’ll test all Netgear switches to ensure if any other models might be affected to this same issue and for affected series, we will provide permanent fix without requiring filtering out these packets using MAC ACL.
We will regularly update the team here on our progress.
Laurent Masia
NETGEAR Senior Product Line Manager, Smart Switches & Managed Switches
elderone
Mar 03, 2017Aspirant
Having same issue with Unifi AC-Pro access points with fw 3.7 and Netgeat switches in spanning tree (rstp).
Netgear switches in spaning tree: GS728TXS, GS752TXS, M7100-24x, GSM7248V2
- LaurentMaMar 03, 2017NETGEAR Expert
Hi elderone
Thanks for your feedback. We are adding these switches to our tests. We started troubleshooting operations simultaneously.
In the meantime, I strongly advise MAC ACL as described above in this post, so that you temporarily alleviate the issue in your network.
- Retired_MemberMar 04, 2017
Hi elderone
Welcome to NETGEAR community.
Can you kindly provide us the detailed GS728TXS/GS752TX/M7100-24X topology when you saw the same issue with Unifi AC-Pro access points?- elderoneMar 05, 2017Aspirant
Here's network layout:
RSTP keeps link open between GS728TXS and GSM7248v2.
Tried also connecting AP-s to GS728TXS, at the same time I did block MAC 01:80:c2:00:00:1c on GS728TXS uplink ports. "My PC" did get access to Unifi AP-s fine, but most of the time Unifi controller didn't get data from AP-s - controller showed that AP-s missing heartbeats, disconnected and occasionally connected.
