XDRich
Feb 15, 2017Guide
STP Leak using Broadcast packet 01:80:c2:00:00:1c
Netgear Support, Please take note that the community and several customers have discovered a possible flaw in your STP implementation that causes CPU panic and circular broadcasts that disable sw...
- Jun 07, 2017
LarryV and to others,
Since a firmware fix is not yet available, the MAC ACL workaround can be used as described on the article below:
DaneA
NETGEAR Communtiy Team
RedTechie
Apr 18, 2017Aspirant
Thanks LaurentMa!
Yeah I actually just checked last night and saw the new firmware! You beat me to replying in this thread that the new version was released. :)
Thanks again, I will give it a try in the next few days!
adinstruments
LaurentMa, did you have an ETA on the new firmware for the GS752TS that resolves this issue?
