RobertMcGonigle
Apr 10, 2020Aspirant
Remote Authentication to Netgear ProSafe GS105PE
Hello,
I'm looking into finding the correct header and payload infomation to change some settings on the GS105PE.
I'm looking to update the VLAN IDs of each port through an HTTP Post request. Any tips, or leads to any online documentation would be great.
I beleive I found most of what I need, but wanted to know how to authenticate in the request header.
Many Thanks,
Robert McGonigle
You may want to check the M4300 Series Switches for AV. To learn more, kindly access the links below:
Network Switches Engineered for AV over IP Systems
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Welcome to the community! :)
I'm afraid to inform you that there is no documentation for the GS105PE switch about on how to update the VLAN IDs of each port through an HTTP post request as well as on how to authenticate in the request header.
DaneA
- RobertMcGonigleAspirant
Thanks DaneA,
I appreciate the response. I can see most of the Header in Dev Tools on firefox, and i understand their is no documentation.
I'm more so looking to see if someone the authentication method.
Looking to control this switch from an AV system, to manage touch panels.
If you or another member of the community knows of a dirfferent managed switch that could do the trick, I'd be open to suggestion. - DaneANETGEAR Employee Retired
DaneA
