Retired_Member's avatar
Retired_Member
Dec 16, 2020
Remove login popup
Unfortunately I bougth a GS108Tv3 switch (btw, not included in the model list when creating a new post!). After my (very bad) purchase I was realized that NETGEAR now mandate to register in order to...
  • schumaku's avatar
    Dec 16, 2020
    After my (very bad) purchase I was realized that NETGEAR now mandate to register in order to enable full functionality of the switch, OK, ma bad product/supplier choice, so I registered. This is my last Netgear product I'll ever purchase or, a IT sconsultant, will never suggest Netgear to anyone.
    All your customers and probably all IT consultants own Android and iOS based mobile phones and many more toys which registers in several ways to many known and unknown players. In fact, this does never stop! Depending where you life or where you travel to, you get even free apps forced added.
    Here for a tiny switch, the few people make big noise about a one-off registration - in comparison to the above it's ridiculous. In exchange, you get limited lifetime warranty (EoS + three years) instead of just the legally required minimum (US twelve months, EU six months, or can you proof that a problem existed as the device was new to get 24 months)?
    And why exactly please? I understand it might be a problem if you are living on a space station or an Antarctica research station and face a chicken-and-egg problem...
    I ckick OK once, that means I'm not interested. How many times do I need to press OK?
    No idea just the [Ok] should do it - the ones we have installed showed a don't remind me again tick bottom right on the intrusive pop-up..
    Time for a firmware update probably?
ProSupport for Business
