Retired_Member
Feb 21, 2019S3300 Device View Java Not Working!
Device: S3300-28X ProSAFE 24-Port Gigabit Stackable Smart Switch with 4 10G uplinks
FW: 6.4.0.19
OS: Win 2012 R2
Device View is not working!
We've installed Java 7u51, and it's still not ...
- Retired_MemberApr 18, 2019
After upgrading the firmware to ver 6.6.4.9, device view still did not work.
Logged in today, a number of weeks later, and device view started to work again.
Strange!
schumaku
Feb 21, 2019Guru - Experienced User
Please use search before posting. Answered and requested an update from Netgear several times already. Most of these switches are old, your's is available since about 2011 for example - but I'm aware some of them are still offered in the market. Newer switches come with the new Netgear Web UI no longer requiring any Java plugin for the device view.
Workaround for now (no, I won't promote running legacy systems/browsers/Java) is to forget the device view - it has very limited functionality anyway.
Retired_Member
Apr 18, 2019After upgrading the firmware to ver 6.6.4.9, device view still did not work.
Strange!
