RugbyWreck
Aug 22, 2019Aspirant
Smart Control Center
I'm getting the message "Polling for agent with no response" from the Netgear SmartControlCenter software when I start it up, no idea why? It worked fine on Friday last when I used it (5 days ago) bu...
- Aug 28, 2019
Hi RugbyWreck,
I suggest, re-install the Smart Control Center and try to disable the firewall of your PC. Please make sure that you are also using the latest version of the software.
JohnCarloV
NETGEAR Community Team
JohnC_V
Aug 28, 2019NETGEAR Employee Retired
Hi RugbyWreck,
JohnCarloV
- RugbyWreckAug 30, 2019Aspirant
Hi johnCarloV,
Thank you for the response, apologies for not replying sooner but I have been out of the office for a couple days. However, upon my return the issue I was having seems to have resolved itself which is odd? The SmartControlCenter is now resolving all of the switches in the network without any changes or updates as far as I can see so I no longer have an issue.
Tom Burbury
