robinchristes
Sep 06, 2018Aspirant
SNMP-OID for the MAC of the connected Device
Hello Community,
i am working on a script, which is collecting data from the switches via SNMP.
My problem is, that i need to know the OID which can be used to find the MAC of a Client direct...
- Sep 12, 2018
I've found the solution:
if the request returns iso.3.6.1.2.1.17.7.1.2.2.1.2.1.0.34.100.189.60.156 = INTEGER: 7, the integer-value represents the port of the MAC-address and the last 6 numbers of the OID represent the MAC-address in decimal format, in this example it means that the MAC-address connected to port 7 is 00:22:64:BD:3C:9C.
Thank you for your help :-)
DaneA
Sep 11, 2018NETGEAR Employee Retired
Please be sure that the MAC address table that you are looking for via the SNMP’s OID is present into the Switch’s GUI.
DaneA
NETGEAR Community Team
robinchristes
Sep 11, 2018Aspirant
