marktpalmer's avatar
marktpalmer
SNMP push Text Config
Is it possible to download a Text Configuration file or a firmware Image to the GS108Tv2 switch using SNMP commands?  If so, what are the correct OIDs to use?  The target switch I am looking at does *not* have the 1.3.6.1.4.1.4526.10 OIDs so please do not answer with "agentTransferDownloadGroup".  The switches I am working with have the "1.3.6.1.4.1.4526.11" OID (or ng700Switch).
  • DaneA's avatar
    DaneA
    Nov 07, 2017
    Hi @marktpalmer,
    I have replied to your post here.  I have edited and updated the download link with the MIB for the GS108Tv2.  You can also download it here.
    You may use the NMS300 to download a text configuration file or firmware image.  You can download the latest version of NMS300 here.
    DaneA
    NETGEAR Community Team
  • Anyone?
    If not possible or unwilling/unable to assist, please provide a link so I can download the GS108Tv2 MIB so I can sort it out myself.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Hi @marktpalmer,
      DaneA
      • marktpalmer's avatar
        marktpalmer
        NMS is a non-starter (cannot use Windows on our platform).
        I have tried to retrieve a file with a known to be working TFTP server, but I get a weird error (its weird because the file I am retireving is the exact file I downloaded via the Web GUI).
        The error is "This file is not intended for this product!" (weird right?).  I also confirmed I could "download" the file to the switch successfully.
        So, it TFTP client broken on the switch?
ProSupport for Business
