Niabu
Jan 14, 2016Aspirant
SRX 5308 Blocked to Login From WAN side
Hi!
I have a little problem. Can`t connect from wan side to my router :(
And I can`t understend what i`m doing wrong...
Chekbox "secure https connection" is active. Firmware is latest.
When I`m trying to connect that blackbox ip, i`m receiving this: Blocked to Login From WAN side
What am I do wrong?
- AnonymousJan 15, 2016
Hi Niabu,
Welcome to the community!
There is a policy set on the admin user by default to block the account to login from the WAN. This is a security mechanism as the admin password is a default password easily available on the internet.
To disable this feature go to Users - Users. For the admin user click on Policies. De-select the option "Deny Login from WAN Interface" and click Apply.
You should change the password from the default password before making this change.
Thanks.
- Anonymous
Hi Niabu,
Thanks.
- NiabuAspirant
Thanks! It was chekbox that I searched!!!
It`s OK now :)
