XDRich
Feb 15, 2017Guide
STP Leak using Broadcast packet 01:80:c2:00:00:1c
Netgear Support, Please take note that the community and several customers have discovered a possible flaw in your STP implementation that causes CPU panic and circular broadcasts that disable sw...
- Jun 07, 2017
LarryV and to others,
Since a firmware fix is not yet available, the MAC ACL workaround can be used as described on the article below:
DaneA
NETGEAR Communtiy Team
Retired_Member
Mar 04, 2017Hi elderone
Welcome to NETGEAR community.
Can you kindly provide us the detailed GS728TXS/GS752TX/M7100-24X topology when you saw the same issue with Unifi AC-Pro access points?
elderone
Mar 05, 2017Aspirant
Here's network layout:
RSTP keeps link open between GS728TXS and GSM7248v2.
Tried also connecting AP-s to GS728TXS, at the same time I did block MAC 01:80:c2:00:00:1c on GS728TXS uplink ports. "My PC" did get access to Unifi AP-s fine, but most of the time Unifi controller didn't get data from AP-s - controller showed that AP-s missing heartbeats, disconnected and occasionally connected.
