XDRich
Feb 15, 2017Guide
STP Leak using Broadcast packet 01:80:c2:00:00:1c
Netgear Support, Please take note that the community and several customers have discovered a possible flaw in your STP implementation that causes CPU panic and circular broadcasts that disable sw...
- Jun 07, 2017
LarryV and to others,
Since a firmware fix is not yet available, the MAC ACL workaround can be used as described on the article below:
DaneA
NETGEAR Communtiy Team
LaurentMa
Mar 05, 2017NETGEAR Expert
Please be sure Engineering team is working on this issue across our portfolio. So MAC ACL is temporary workaround only. But very efficient.
Yes please apply the MAC ACL discarding these packets, on all ports which are connecting the Access Points. It is not necessary to bind the ACL with other ports.
