XDRich
Feb 15, 2017Guide
STP Leak using Broadcast packet 01:80:c2:00:00:1c
Netgear Support, Please take note that the community and several customers have discovered a possible flaw in your STP implementation that causes CPU panic and circular broadcasts that disable sw...
- Jun 07, 2017
LarryV and to others,
Since a firmware fix is not yet available, the MAC ACL workaround can be used as described on the article below:
DaneA
NETGEAR Communtiy Team
RedTechie
Mar 05, 2017Aspirant
I have a few LAGs and the native stacking functioanlity of the GS752TXS's enabled. See Image.
Do I need to add it to all of them (including the stacked links)?
Also the "quick notify" is that the zero-handoff config? As I am not using that:
Or is quick notify something completely different with the UBNT hardware?
adinstruments
We have the same issue.
Our Netgear switch setup looks like this:
- Level One: Switch Stack of 2 x NetGear GS752TS Switches
- Level Two: Switch Stack of 5 x NetGear GS752TS Switches
These stacks are connected via a 6 port LAG. Could we please add the GS752TS to the list of switches needing a FW fix for this issue.
