XDRich
Feb 15, 2017Guide
STP Leak using Broadcast packet 01:80:c2:00:00:1c
Netgear Support, Please take note that the community and several customers have discovered a possible flaw in your STP implementation that causes CPU panic and circular broadcasts that disable sw...
- Jun 07, 2017
LarryV and to others,
Since a firmware fix is not yet available, the MAC ACL workaround can be used as described on the article below:
DaneA
NETGEAR Communtiy Team
LaurentMa
May 22, 2017NETGEAR Expert
I just wanted to provide final update on this very important topic, all maintenance releases fixing the issue were published on http://downloadcenter.netgear.com/
Smart Managed Switches:
- FS728TPv2: 5.0.2.46
- GS728/752TS/TPSB: 5.3.0.31
- GS748Tv4, GS7xxT, GS1xxT, FS752TP, GS510TP: 5.4.2.30
- GS752TXS, XS712T: 6.1.0.36.
- GS716Tv3/GS724Tv4/GS748Tv5: 6.3.1.17
- S3300, XS708T/XS716T: 6.6.1.7
- GS418TPP, GS510TLP/GS510TPP: 6.6.2.7
elderone
May 22, 2017Aspirant
What about fixed firmware for GSM7248v2 and M7100-24X switches?
