VinceFerr
Feb 16, 2018Aspirant
switch con porte sfp+ da 10Gb
Stavo guardando alcuni switch 1Gb con 2/4 porte SFP+ da 10Gb. Scrivono tutti porte da uplink/stacking, cioè dovrebbero servire per collegare altri switch e usare una banda fino a 20-40Gb tra i vari ...
- Feb 17, 2018
Reason for my curiosity question was hat I was not aware of such a Netgear switch model with GbE plus four SFP+. On the GS728TX (and all four S3300 models), of the four dedicated 10 GbE ports are two 10GBASE-T, and two are SFP+:
Said that, all the 10 GbE ports are generic ports, available for any purpose at any speed (except of the new 2.5G and 5G MultiGig).
What I don't know is if Netgear does enforce the usage of Netgear SFP+ modules with a Netgear ID on this model line.
VinceFerr
I'm sorry, I thought I was in the italian section...
Anyway I was looking at some switches with sfp+ ports with 10Gb: they say they can be used to uplink/stack other swtiches at 20-40Gb.
My question was if I have 4 sfp+ 10Gb ports on a 1Gb switch, can I use these ports to directly connect 4 pc with 4 10Gb sfp+ boards and sfp+DAC cables? Do they communicate among them at 10Gb or with other machines in the switch at 1Gb?
