Citizen0135
May 24, 2018Aspirant
Trouble with Computers connected through Phones on GS728TP
I have a site that has upgraded to fiber internet with hosted voice. The service provider has VLANS 10 (data) and 20 (voice) configured on their router. The computers at the site will be connecting b...
- May 29, 2018I figured it out. The ISP did not fully configure the phones. They should have specified the VLID in the device once I did this the traffic started passing properly
JohnC_V
May 25, 2018NETGEAR Employee Retired
Hi Citizen0135,
Welcome to our community! :)
I would like to know the VLANs that will be used for data and voice? Do you mean VLAN 10 and 20 are for data VLAN? How about for the voice VLAN? Basically, if you wanted to pass the data traffic to your PC, you may just need to assign the PVID to their corresponding DHCP server.
Example:
VLAN 10 - Office 1
VLAN 20 - Office 2
VLAN 99 - Voice
VLAN membership:
VLAN 99 - Port 1 - T
VLAN 99 - Port 2 - T
VLAN 10 - Port 1 - U
VLAN 10 - Port 2 - U
PVID Configuration (where you wanted it to have a DHCP request for your PC):
Port 1 - PVID 10
Port 2 - PVID 20
On this setup, port 1 will receive an IP from DHCP server of VLAN 10 and port 2 will be receiving from VLAN 20 as it was assigned to their corresponding VLAN.
May the solution help you. :)
- Citizen0135May 29, 2018AspirantI figured it out. The ISP did not fully configure the phones. They should have specified the VLID in the device once I did this the traffic started passing properly
