Cadcam's avatar
Cadcam
Follower
Oct 23, 2023
Trying to Access Admin Page for GS110TPv3
So I changed to static IP to a IP address trying to sperate the IP address. Little did I know I changed it to the same as our Wireless access point and now I can not access the admin page. I want know is there a way I access the admin page with having to change the AP's or do I need to through console command?
Please Advise.
1 Reply
  • schumaku's avatar
    schumaku
    In absence of a physical console on these Smart Switches, what magic wonders do you expect?
    Either remove the wireless AP with the duplicated address from the network (so you can access the switch LAN IP again), or disconnect the switch from the rest of the network, and bring it up with just a single computer connected, with the adapter configured to a LAN IP address in the same IP subnet range.
    Worst case, factory reset the switch (it defaults to DHCP) and run the Netgear Switch Discovery Tool to find the switch new IP address. Then reconfigure from scratch.
