RNUK
Dec 14, 2020Aspirant
Tuya / Lidl smart home devices don't work when connected to GS724Tv4
Hi All,
Got a strange one here.... bought a Lidl smart home device and connected it via my switch. It's a rebadged Tuya device. When I search for the gateway, it eventually finds it, but it cannot be registered. Thinking it may be faulty, I switched it for another one, but this did the same. I tried many things to fix, but eventually found this thread:
Thinking it may be Netgear related, I connected it directly to my Asus router. It started working and I was able to register. When I tried it to a new port on the GS724Tv4, it failed again.
Any one have any ideas what could be causing this. Unfortunately the distance between my smart deviced and the gateway are too great, so I need to be able to use it in the switch.
I've upgraded to the latest firmware 6.3.1.36. I moved the device back to the switch once it had been registered. The App then doesn't detect it.
do hyou have the dhcp server enabled on the smart switch?
What router is connected to the switch?
And what gateway/modem are you using?
- RNUKAspirant
DHCP on Netgear switch - No
Asus RT-AC88U with latest firmware - DHCP running there
Huawai Echolife HG612 modem
When I connect to RT-AC88U, the device works.
the Echolife HG612 also has an integrated router dhcp server.
Add in the asus and it can create a double nat.
RNUK wrote:When I search for the gateway, it eventually finds it, but it cannot be registered.
The initial discovery after reset and plugging as well as the discovery used later makes use of the very same UDP broadcast.
Up to here it does not make any sense.
The controller does pick up an IP when plugged to the switch reliably?
I do assume that the Asus router does handle the broadcast properly, regardless of the radio band used as both radios connect to the same network and IP subnet anyway - even if the vendors of this IoJ insist the 2.4 GHz WLAN must be used.
- RNUKAspirant
schumaku wrote:Up to here it does not make any sense.
Yes, it appears to. When I search for the gateway, the App (Lidl or Tuya) finds it, and it's only when you try and go to the next stage it doesn't do anything - and of course, if I disconnect it any move it back to the switch. In that case, the app no longer finds it. In the Tuya app, select ZigBee Gateway, top right, Check Device Network. It connects ok, and then performs a test. Strangely the IP address it is reporting is a different IP to what 'what is my ip address' reports.
I am assuming it is getting an address ok. It does have 'two' IP addresses according to Fing. The DHCP one and 192.168.1.254. The pool ends at .199. I have a couple of devices which have fixed addresses. The switch being one.
Not sure why it talks about 2.4Ghz WLAN. The device is physically connected. I think they do make a wireless version - maybe that's why. I disabled 5G and it didn't make any difference.
Ignore the 2.4 GHz question ... while it's part of the Lidl packaging and user booklet, it does not make any sense. Only the Tuya App seems th throw the message, the Lidl Home variant either didn't or I don't remember. Fully agree, in my understaning it's not a WiFi client, only Ethernet.
Is there anything configured on this GS switch? VLANs, routing, ACLs, ...? Some left-over lag configs or the like? Any chance for a factory reset?
Have an eye on the switch MAC table - all normal?
Hard to imagine the gateway does make use of both IP addresses - at least this would be fishy.
- jippAspirant
Have you tried the STP settings? specifically BPDU Flooding = ENABLE
By default it is disabled, never had issues since,
I have a GS724Tv3 and when I first got some Google Home Wifi mesh devices, they would work and sometimes discover, but had horendous issues with meshing and disappearing from the app.
After much searching a post mentioned this BDPU setting, which is only needed on managed switches it seems, a simple dumb switch works fine.
I wonder if this affects the discovery issue you are having with your smart device?
