RockSteadyEddie
Sep 10, 2016Follower
Unable to access internet from VLAN2 (GS105Ev2)
Set up using defaults i.e. all ports on VLAN 1, DHCP addresses picked up by clients and can access the internet (via default gateway, no problem). When I create a second VLAN (2), devices connected t...
- Sep 11, 2016
Hi RockSteadyEddie,
Welcome to the community! :)
Kindly answer the questions below:
a. Is your GS105Ev2 connected to a router? If yes, what port on the GS105Ev2 is connected to the router?
b. Is the router a VLAN-aware device?
c. What ports are members of VLAN 1 and VLAN2?
d. Have you double-check the PVID configuration of each port?
Let me share the link below I found online and use it as a guide:
Configuring a Netgear GS105E Switch with LAN/WAN ports
DaneA
NETGEAR Community Team
DaneA
Sep 14, 2016NETGEAR Employee Retired
Hi RockSteadyEddie,
I just want to follow-up on this.
DaneA
