LaboDJ
Jan 08, 2023Follower
Unable to reach JGS524PE via WireGuard VPN
Hi,
I have a problem with a JGS524PE (FW 2.6.0.48) web GUI that it's not reachable behind a wireguard tunnel.
It's reachable normally without wireguard by any client on the same subnet.
The error using a web browser is: ERR_CONNECTION_REFUSED
The error using curl is the same: curl: (7) Failed to connect to 192.168.21.2 port 80 after 2465 ms: Connection refused
My setup is pretty simple and straightforward:
WAN -> Router -> JGS524PE -> Clients / AP / Other switches
Normal LAN clients subnet: 192.168.21.xxx
Wireguard clients: 10.9.0.xxx
No VLAN
Wireguard endpoint is offered by a client directly attached to JGS524PE
Every other clients is reachable from WAN to LAN and viceversa, even a Netgear GS108Tv3 connected to JGS524PE
Access control doesn't solve the issue, the other switch (GS108Tv3) is working fine even using deafult settings.
Any help?
No RepliesBe the first to reply
