coyote3's avatar
coyote3
Guide
Jan 27, 2021
upgrade GS108Tv2 firmware on Linux?
I don't have a Windows PC anymore to upgrade to the new firmware for my GS108Tv2, so how do I in Linux Mint? (I used to use the Smart Control Center.exe) I figured I'd try to reach the webpage ...
  • schumaku's avatar
    Jan 27, 2021
    Cold reboot the switch and check the router attached device for the logs for the DHCP server ip address assignment to the switch MAC.
    Alternate, install Netgear Insight on your Android device and check if the switch can be discovered on the network.
ProSupport for Business
