pealie1
Aug 25, 2015Follower
Upgrading the firmware for Prosafe XS712T
I am using SmartControlCenter to upgrade the firmare for subject switch. Which archive does one use to do so? There are 3 possible files: the downloaded zip, the mibs zip, and the stk. Can someone p...
- Aug 25, 2015
Hi pealie1,
Use the xs712t-v6.1.0.34.stk to upgrade the Firmware of your switch.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
BrianL2
Aug 25, 2015NETGEAR Employee Retired
Hi pealie1,
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
