RichFlickinger
Mar 30, 2023Aspirant
VLAN Config Can't get out to internet
Hi Folks,
I am a VLAN newbie so i am sorry if i'm not explaining this right or have the terms wrong. Anyway, I'm trying to setup this switch with a VLAN that can get out to the internet. The internet router is plugged into port 8 and my laptop into port 4
VLAN IP's
VLAN Ports
VLAN Port ID's
Switch Routing Table
Static Route on Internet Router
My Laptop Ethernet Settings
The ultimate goal is to isolate the media equipment at church, but it needs to get to the internet for live steaming. I wanted to figure it out at home first.
Any help would be greatly appreciated.
- Retired_Member
What about the Routing Mode under Routing>IP>IP Configuration? Is it enabled?
- RichFlickingerAspirant
Yes, it is.
- Retired_Member
Are you able to ping 192.168.1.254 and 192.168.1.1?
