billycee
Feb 09, 2019Aspirant
VLAN Configuration
Hi everyone, this is my first time I've encountered Netgear switches in enterprise setups and I'm finding the vlan configuration slightly confusing to say the least. I'm hoping that I'll be put on th...
- Feb 09, 2019
Tag the switch port 1 (uplink port to firewall router) VLAN 22.
MX firewall connected to port 1 of NETGEAR switch as uplink port.
Access point is VLAN unaware device since you set the PVID to 22 and untag the port 12 VLAN membership.
billycee
Thanks so much, that worked. The AP is now online
There is also another Netgear switch connected to the first one via fibre.
- Netgear switch 1 fibre port 25 connected to Netgear switch 2 fibre port 25
- Meraki Access Point connected to port 20 of switch 2
Is this configuration for Netgear switch 2 correct?
- Port 20 tagged in vlan 22
- Port 25 untagged in vlan 22
Thanks in advance.
Nodism1125
Feb 11, 2019NETGEAR Expert
Hi billycee,
Switch 1 is connected to Switch 2 via fiber tag the uplink port 25.
Create the same VLAN 22 to Switch 2 and member 20 as untag port
If the Meraki AP is VLAN unaware, untag the port 20
How do I setup a VLAN trunk link between two NETGEAR switches?link
