meinit's avatar
meinit
Tutor
Jun 26, 2020
VLAN ID limitation?
I'm configiring this switch for my network and the existing VLAN i need to connect it to is 100 . In the configuration,
VLAN -> Port Based -> Advanced -> VLAN Identifier .
The VLAN ID goes up to 24. Is there a way to configure the swicth to use a VLAN higher than 24 ?
  • For fully flexible 802.1q VLAN config use VLAN -> 802.1Q -> Advanced etc.
  • schumaku's avatar
    schumaku
      • schumaku's avatar
        schumaku
        Be careful using only the very same entry - using another VLAN "mode" by accident will erase the config in place for another VLAN mode.
ProSupport for Business
