Victor-R
Apr 24, 2018Aspirant
VLAN on XS728T so switch can connect to internet
I have a simple newbie question: We have a 10.0.1.x LAN on the switch which we do not want to have internet access. But, I need a VLAN port that can access our 192.168.1.x LAN simply so the switch can register with NETGEAR(plus software updates) and access SNTP servers
I set up VLAN ID #2 with PVID 2, and "U" (untag) port xg9 to it
Is there anything else I need to do?
Ok, I think I figured it out...
Routing>VLAN>VLAN Routing Wizard allowed me to assign a 192.168.1.x address to port xg9
Unless I'm wrong, the product registration and the check for updates does happen from the Web browser, not direct from the switch. However, the network time and date functionality does require some network access.
Of course you could set-up some routing ie. on the switch, and add some additional route on your router (if it allows it at all) - one has to be rather hard core to do this. Comes the question if moving the management to a Internet routable subnet (and VLAN of course) would not be much easier?
- Victor-RAspirantHi Schumaku, thanks for responding.
I agree about browser registration. Well, at least, that’s how I registered our original XS728T 3 years ago. This current one is a warranty replacement from NETGEAR. I keep getting pop up warnings that automatic registration failed. And, that I need to connect the switch to the internet
“Comes the question if moving the management to a Internet routable subnet (and VLAN of course) would not be much easier?”
This is exactly what I want to do! Sorry for the confusion, I posted the thread around midnight after a 15 hour day.
I just couldn’t figure out how dedicate a switch single port to the 192.168.1.x network that our router is on. While the rest were dedicated to the 10.0.0.x network- Victor-RAspirant
