EthanB21
Apr 01, 2021Tutor
Voip vlan and firewall DHCP not passing
An unfortunate accident forced me to factory default our main netgear switch, and I am trying to pick up the pieces and make it work again. Internet on Vlan 1 works just fine. However our Voip phones...
- Apr 06, 2021
Welcome to our community! :)
It seems that you are having issues with the switch. I believe most of your devices are configured on a VLAN as most of your devices can receive an IP. May you be able to check the firewall if there are any VLANs configured so that we can also assign/create it to the switch?
John
NETGEAR Community Team
JohnC_V
Apr 06, 2021NETGEAR Employee Retired
John
- EthanB21Apr 08, 2021Tutor
Solution found, simply needed to manually tag ports in the VLAN as 2 in the Switching>Vlan tab. Touching anything in Switching>Voice Vlan|Auto Vo-IP tabs caused it to not work.
