830se
Jul 12, 2021Aspirant
What are the exact dimensions of the barrel plug on the power adapter for GS110TP smart switch?
I'm looking for exact dimensions of the barrel on the power plug for a NETGEAR GS110TP smart switch i.e. inner and outer diameter in millimetres.
Here below are the measurements of the barrel of the power plug of the GS110TP switch:
Outside diameter is 6.5mm
Inside diameter is 3mm
Barrel length is 9.5mm.
DaneA
NETGEAR Community Team
2.1 mm and 5.5 mm most likely - compare to your GS110TP unit if this makes sense.
- 830seAspirantThanks for the reply.
Unfortunately the dimensions are not 2.5x5.5mm. Using a ruler I can see the outside diameter is roughly at least 6mm and the inside diameter is at least 3mm. I'm really looking for the exact measurements.- schumakuGuru - Experienced User
No other choice than measuring the inner pin with the right tool and compare with the available connectors - probably 3.1 mm inner, 6.3 mm outer.
