Bob5353
Jun 20, 2025Aspirant
What happened to GS308T ?
Hello I am searching for a new switch and found Netgear's "GS308T" (notice the 'T' at the end, not to be confused with any other switch with a similar model designation.) But as I search for...
Bob5353
Hello Kurt, thanks for the helpful answer.
Yes, I draw the same conclusion that GS108Tv3 is the alternative product closest to GS308T.
Another thing I find strange is that both GS108Tv3 and GS308T show as EoS at https://www.netgear.com/about/eos/(the EoS search is a bit wonky if anyone tries it out)
However, the product page for GS108Tv3 has nothing about it being an EoS product. I get purchase offer "Add to cart" and GS108Tv3 can be delivered in a couple of days. https://www.netgear.com/business/wired/switches/smart-cloud/gs108tv3/
I can also find plenty of stores selling GS108Tv3.
So, to summarize:
- schumakuJun 20, 2025Guru - Experienced User
As I said, I'm not Netgear - have challenged them for a complete and correct product life cycle documentation both customers, system integrators -and- sales can depend on. Iphie_C IphieChen
