E71
Sep 07, 2016Aspirant
What version of GS724T does not require JAVA?
Hi all, Does anyone know if GS724Tv2 requires Java Runtime for its web interface? I need a GS724T that works without Java but it seems that version 3 (GS724Tv3) onward DOES require it. Un...
- Sep 08, 2016
Hi E71,
I believe that Java runtime is not required in accessing the web-GUI of the GS724Tv2.
DaneA
NETGEAR Community Team
DaneA
Sep 08, 2016NETGEAR Employee Retired
Hi E71,
DaneA
E71
Sep 08, 2016Aspirant
Thanks.
- DaneASep 11, 2016NETGEAR Employee Retired
Hi E71,
You're welcome! :)
Feel free to post your future concerns here in the community.
DaneA
- hokie21Sep 20, 2016Tutor
I have the v3 and I would not say that Java is required. There is one page that doesn't work without Java, but the functions on this page can also be accessed using other non-Java tabs. Blinking lights using Java are nice, but not required.
- NapsterbaterSep 23, 2016Apprentice
I have a v4/400nas. Like poster above, one page, which I think is suposed to dispaly a visual of the switch" dosnt work, but its not needed, all settings and funtions are asseiclbe with out it.
