brossow
Jul 09, 2018Tutor
What's this "communication problem access Netgear Registration server" alert about?
Setting up my new-to-me GS724TPv2 on my home network. Every time I log in, it gives me this alert:
Error: there is a communication problem access Netgear Registration server, registration proce...
- Aug 21, 2018
I just want to inform you that the issue discussed here in this forum thread was already confirmed as resolved by the higher tier of NETGEAR Support.
It has been more than a month already and I observed that there were no new posts here in the community related to the issue being discussed here in this forum thread. With regard to this, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
brossow
Jul 09, 2018Tutor
Disregard. After updating the firmware, the message has gone away.
Nope, still there. Just took a bit to pop up. If I go to Help > Registration and click the Register link, I get this: "Error: The Registration Server is not accessible; please check your internet connectivity or try at a later time." My internet connection is fine; I'm posting this while connected through the switch. :(
