brossow
Jul 09, 2018Tutor
What's this "communication problem access Netgear Registration server" alert about?
Setting up my new-to-me GS724TPv2 on my home network. Every time I log in, it gives me this alert:
Error: there is a communication problem access Netgear Registration server, registration proce...
- Aug 21, 2018
I just want to inform you that the issue discussed here in this forum thread was already confirmed as resolved by the higher tier of NETGEAR Support.
It has been more than a month already and I observed that there were no new posts here in the community related to the issue being discussed here in this forum thread. With regard to this, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Jul 10, 2018NETGEAR Employee Retired
Hi brossow,
Welcome to the community! :)
Since you have updated the firmware, it would be best to perform a factory reset then reconfigure the settings from scratch in order to start clean using the latest firmware version.
Let us try this. Kindly set a DNS Server on the GS724TPv2 switch. You may set 8.8.8.8 or 8.8.4.4 as DNS Servers. Kindly read pages 53-54 of the GS724TPv2 user manual on how to configure DNS Settings. Then, check if you will encounter the same error message again.
DaneA
brossow
Jul 10, 2018Tutor
One of the first things I did was to update image2 to firmware v1.1.1.10, which is the latest version according to the support page for this model. I did a factory reset after that and went through basic setup (SNTP and DNS) but was still getting these messages. Just the same, I did another factory reset just now and am getting the same errors even after making the suggested DNS changes.
I see a new firmware (v1.1.1.13) has been released but is not yet listed on the product page. I'll try updating the firmware again, then factoryr reset, then configure DNS (again!) and see what happens.
Not to change the subject, but is it normal to have to start from scratch after every firmware upgrade? I've never experienced that with any other networking hardware and am quite surprised that's acceptable in enterprise hardware. Or is that just "recommended" and not strictly necessary?
- brossowJul 10, 2018Tutor
Same thing after v1.1.1.13 firmware update. It's not like it's a big deal to clear the error message, but between those and the very poor attention to basic proofreading, it's hardly a great first impression with this hardware. It doesn't instill confidence. :smileyfrustrated:
- schumakuJul 11, 2018Guru - Experienced User
Any firewall rules (or mandatory proxies) prohibiting the (suspect correct configured) switch to talk to the Internet resp. the registration servers?
- brossowJul 11, 2018TutorNo, there's nothing at all. The setup is DSL modem > ASUS wireless router > Netgear switch > everything else. Aside from wireless clients, all traffic is going through the Netgear switch with zero issues. It's just the switch itself that seems to have issues. Even having said that, the switch is able to connect to an SNTP server without complaint. It's only talking to its own registration server that it can't seem to handle. It's bizarre.
