brossow
Jul 10, 2018Tutor
What's this "communication problem access Netgear Registration server" alert about?
Setting up my new-to-me GS724TPv2 on my home network. Every time I log in, it gives me this alert:
Error: there is a communication problem access Netgear Registration server, registration proce...
- Aug 21, 2018
I just want to inform you that the issue discussed here in this forum thread was already confirmed as resolved by the higher tier of NETGEAR Support.
It has been more than a month already and I observed that there were no new posts here in the community related to the issue being discussed here in this forum thread. With regard to this, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
schumaku
Jul 11, 2018Guru - Experienced User
Any firewall rules (or mandatory proxies) prohibiting the (suspect correct configured) switch to talk to the Internet resp. the registration servers?
brossow
Jul 11, 2018Tutor
No, there's nothing at all. The setup is DSL modem > ASUS wireless router > Netgear switch > everything else. Aside from wireless clients, all traffic is going through the Netgear switch with zero issues. It's just the switch itself that seems to have issues. Even having said that, the switch is able to connect to an SNTP server without complaint. It's only talking to its own registration server that it can't seem to handle. It's bizarre.
- DonnieCJul 12, 2018Aspirant
Same here ... just installed 2 GS752TP switches and every time I login via web browser I get this error:
Error: there is a communication problem access Netgear Registration server, registration process is cancelled, please check your Internet connection, and register the product next time you login.
Irritating seems the biggest effect is that I have to simply close the window ... but it's always worrisome to have a pop-up error dialogue box that cannot be explained or fixed.
- DaneAJul 17, 2018NETGEAR Employee Retired
I inquired your concerns to the higher tier NETGEAR Support and got a feedback that a fix is currently being worked on.
DaneA
- brossowJul 17, 2018Tutor
Thanks. If we're really lucky, they'll also get a good tech writer to look over the warnings and fix all the errors there.
