mrdunn
Feb 03, 2017Aspirant
When I connect my gs611e v2 switch to my Netgear Nighthawk router, I immediately lose my internet.
I returned a defective GS611e switch and received a new GS611e v2 switch. When I connect it to my Netgear Blackhawk router, I immediately lose my internet connection. I have tried many reboots of modem, router and switch, reset to factory defaults many times, etc. Even tried a different router, same results. My dumb switches work fine. My router is set for DHCP as is my switch. About ready to throw it away and get a dumb switch, unless someone can help me. I can configure the switch with the utility, tried to make a static IP, no change.
Well, it turned out it was connected to the wrong power supply. Instead of using the one that came with v2, I used the one from v1, When I changed the power supply as someone hinted in the past, everything works. Wasted several hours troubleshooting.
1 Reply
- mrdunnAspirant
