pgjscottieuk
Sep 21, 2022Guide
XS708E Plus Switch Problems connecting to Admin Page
Purchased a second hand XS708E downloaded ProSafe Plus Configuration Utility V2.7.8 the switch showed up let me assign a static IP address but that's all switch selection nothing can see what firmwar...
- Sep 21, 2022
Alright so when you select the XS708E and then click on Apply nothing happens? or
After clicking Apply the IP settings shows up?
Have you tried providing the Password on the IP settings and then hitting Apply? If yes, what happens after that?
If the Tabs are not really showing up you may want to try doing a Factory reset first.
If possible post the screenshot of what is happening after providing the password or after selecting the switch and hitting apply.
Many thanks
Marc_V
Sep 21, 2022NETGEAR Employee Retired
Many thanks
pgjscottieuk
Sep 22, 2022Guide
After launching the Pro safe Plus Utility highlife the switch clicked apply as per your suggestion password window opened entered the default password bingo got into switch reset to default job done thank you for your help
