ikatutu's avatar
ikatutu
Netgear XS708e connecting to cisco Catalyst 2960
Hi guys
I bought a Netgear XS708Ev2|ProSafe Plus 10G 8 ports switch to put it with our cisco network, but I am having trouble connecting it to cisco catalyst 2960
Is anybody work with this specific Netgear switch to connect it to the cisco switch?
I want vlan 5 and 10 to pass through the netgear - 5 to be a management vlan and vlan 10 will be a server vlan
On the cisco switch assing the port that direct connect to the netgear switch to be a trunk port so it will allow more than one vlan to pass throug that port...
On netgear switch I assigned its ip address to be on the management subnet, but cant even ping from the cisco switch
I know that netgear doesn't have trunking option on all the ports.
Is any way I can establish the connectivity between these two switches and able to pass through those vlans?
Thank you very much
  • Thanks for your help... I did put T on the direct port toward cisco switch with PVID of 1 and a member of all vlan, and still not working... so i decided to put the netgear as a dump switch and put native vlan 5 on my cisco switch to point to the management ip address of the netgear which within a management subnet address... and works fine...
    I am still looking on why it was not working with putting T on a port with PVID = 1 and All vlans.
    but thanks again for your help.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi ikatutu,
    Welcome to the community! :)
    The port(s) on the XS708E that is connected to the Cisco Catalyst 2960 should be set as tagged (T) with a PVID of 1 and it should be a member of all VLANs.
    As reference guide, click on the article below:
    Setting up VLANs between Cisco and NETGEAR Switches
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    Hi ikatutu,
    Feel free to post your questions.
    DaneA
    • ikatutu's avatar
      ikatutu
      • DaneA's avatar
        DaneA
        Hi ikatutu,
        I'm glad to know that it works fine. :)  I appreciate that you've shared what the steps you've done.
        Since the problem is now resolved,  I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
        Cheers,
        DaneA
ProSupport for Business
