daball
Dec 29, 2025Aspirant
XS712Tv2 factory resets itself
Bought a used XS712Tv2 on eBay back in July. I had a lot of trouble with setting it up initially. Once I got it working I upgraded the firmware to latest and stored the latest firmware on both image1...
daball
Dec 31, 2025Aspirant
So I removed the enclosure panel and unplugged the ribbon cable running to the power led, fan led, and reset and factory default momentary switches. We'll see how it goes. I suspect a bad momentary switch at the factory default position.
