shpokas
Aug 22, 2022Follower
XS712Tv2 switch - L3 routing between two separate networks?
Hi, There are two different entities that however trust each other to a certain degree. Each entity has it's own LAN and switches and gateway and internet connection. I need to interconnect these ...
DaneA
Aug 25, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Would L3 routing on switches somehow would make this task easier so that I don't have to add a VLAN tagged interface on each device?
It depends on how well you know how the network is configured on the Mikrotik side and your side.
can L3 routing as I see it on XS712v2 switch coexist with 802.1q tagged VLANs?
L3 routing is not supported on the XS712Tv2 switch. However, if there is already an existing Layer 3 switch with Layer 3 routing configured properly, the XS712Tv2 switch should work with it given that it is also properly configured.
DaneA
NETGEAR Community Team
