Squuiid
Jul 07, 2023Luminary
XS728T fan replacement options
I wanted to create a post to help anyone looking for replacement (quieter!) fans for the XS728T switch. While the XS716T and XS708T are easy, with direct Noctua swap ins, the XS728T is an entirely di...
Jan 14, 2024Guru - Experienced User
Just wondering why you would have such a noisey device in the bedroom?
I'd put in a non managed fanless small switch in the bed room and place this one else where if it was me. But to each his own.
iieeann
Jan 15, 2024Aspirant
I bought this switch when i was staying single, so i can put it anywhere i like. Now Im staying with family and they are annoyed by the noise (the netgear switch + Synology XS NAS were pretty noisy), they also complaint those devices were eyesore, so i have to move them to the room. i kept the netgear switch in the box and use only non-managed fanless switch, turn on the NAS only when i need it.
The old Synology NAS was later replaced with quiet all flash NAS that can also be put in the bedroom. The idea of reviving netgear switch came after i read about people replacing the fan, so i want to try it out. The build quality of this netgear switch should be better than the cheapest fanless switch in the world, so if the noise can be dampened then i might as well use the netgear switch at least i can change the jumbo frame size.
