Squuiid
Jul 07, 2023Luminary
XS728T fan replacement options
I wanted to create a post to help anyone looking for replacement (quieter!) fans for the XS728T switch. While the XS716T and XS708T are easy, with direct Noctua swap ins, the XS728T is an entirely di...
iieeann
Jan 15, 2024Aspirant
I bought this switch when i was staying single, so i can put it anywhere i like. Now Im staying with family and they are annoyed by the noise (the netgear switch + Synology XS NAS were pretty noisy), they also complaint those devices were eyesore, so i have to move them to the room. i kept the netgear switch in the box and use only non-managed fanless switch, turn on the NAS only when i need it.
The old Synology NAS was later replaced with quiet all flash NAS that can also be put in the bedroom. The idea of reviving netgear switch came after i read about people replacing the fan, so i want to try it out. The build quality of this netgear switch should be better than the cheapest fanless switch in the world, so if the noise can be dampened then i might as well use the netgear switch at least i can change the jumbo frame size.
BrianL
Jan 16, 2024NETGEAR Moderator
Thank you for sharing your suggestions and tips on how to use, and install quieter fans in your NETGEAR ProSafe XS switches. With that being said, please do take note that hardware and support warranty will be voided if such parts replacement has been done with your units.
Kind regards,
- CpgeekJan 16, 2024Aspirant
This is certainly an important note for everyone, but I purchased my switch used and the warranty doesn't transfer to the best of my knowledge even if there was still a warranty on it when i got it (which i'm pretty sure it was used longer than the warranty period anyway.
Further (I am not a lawyer, this is not legal advice), I believe that in the united states, a company can't void a warranty when a user repairs their own device, though claims on that warranty CAN and SHOULD be denied if those repairs that the user did interferes with the proper operation of the device and that malfunction has to do with the specific claim placed.
for example, if I have a warranty on my car, decide to change out my stereo, and my water pump dies, they can't deny the warranty claim to repair the pump because I've modified my vehicle.
- iieeannJan 17, 2024Aspirant
I understand about the warranty part, i did it only after the warranty expired. Compared with throwing this switch in the corner of store room, i might as well revive it with something better that i can think of. So today the switch is happily working again.
I did break one of the capacitor solder leg while over drilling, but i managed to solder it back.
