SMcM86
Dec 22, 2025Aspirant
WAC124 AP/router - cannot login
We have two WAC124s, both configured as access points and connected via ethernet to the router.
These were straightforward to configure when we bought them and have worked well. However I recently tried to log into them and cannot access either of them. Trying to log in when they are connected to the internet takes you to the Netgear page - entering the login details results in some 'thinking' before the login page is just redisplayed. As an aside, why one has to connect to a server hundreds or thousands of miles away to access a device just a few feet away is beyond me.
Disconnecting the devices from the internet and connecting directly, as described in the user manual, just results in a failure to connect. I do not believe that both devices suddenly developed the exact same problem so I'm baffled.
I'd be most grateful for any suggestions. Thanks.
Typical "issue" when operating these WAC124 (or similar) in Access Point Mode - you can't use the http://routerlogin.com/ First reference to this is in the fine WAC124 User Manual https://www.downloads.netgear.com/files/GDC/WAC124/WAC124_UM_NEW_EN.pdf p.18.
- SMcM86Aspirant
Thank you both. Unfortunately I have already tried both these options, basically logging in via the device's IP address.
Both the WACs have been working fine, and still are, since they were set up about three years. I only tried to login to update the firmware, to find neither device could be accessed. I'm struggling to believe that both devices developed the same fault at the same time so I'm wondering if Netgear has changed the login process or criteria?
Many thanks.- schumakuGuru - Experienced User
Likely yet another Netgear "classic", caused by a braindead "single sign-on" implemented on these APs - and removed along with the last update since April 2019 (...) - Netgear has not changed anything on this WAC124 since.
The only way to login is operate the AP standalone with -no- Internet access (disconnect the router from the Internet, restart the WAC124) or operate the WAC124 on a direct network cable between a computer (not doing some magic NAT ..., no DHCP, ...), configure the computer to an IP address like 192.168.0.123/24 (255.255.255.0), then you should be able to login locally on the default DHCP fallback IP address 192.168.0.100 - and update to WAC124 Firmware Version 1.0.4.9
Try using the IP address of the the WAC to log in?
Happens in other different browsers?
Power OFF the WAC's and reboot the host router and then try again?
