donjajo
Dec 18, 2025Aspirant
WAX204 cannot run on UPS
I have a WAX204 which I need to plug into a UPS. It runs okay if the UPS is plugged into AC power. However, whenever the power goes out, the router reboots and gets stuck in a boot loop. The loop hap...
Dec 19, 2025Guru - Experienced User
donjajo wrote:I had thought it was the UPS power
It must be, but probably not the amount of power. More likely the quality of the power.
Possibly this is because the output of the UPS is PWM (pulse width modulation), which gives a stepped sine wave, and not a true sine wave. But this is just speculation. FWIW, HikVision does make on-line UPS that provide true sine wave output.
Are you using the original power adapter for the AP? Possibly a different adapter would give different results.
