c420ramsay
Feb 28, 2020Follower
Advice in relation to daisy chaining a 16-Port PoE/PoE+ Gigabit Ethernet switch GS116LP
Looking for some advice: I have one GS116LP 16 port GB switch and I am looking to Daisy chain another one to increase capacity. Am I safe enough buying the same one again to daisy chain to it or wo...
- Feb 29, 2020
Ìt depends on the number of ports you need, on the PoE standard (PoE, PoE+, ...), the number of PoE ports, ...
schumaku
Feb 29, 2020Guru - Experienced User
