Tunesmith
Jan 14, 2023Aspirant
Audio over internet GS108LP
I'm setting up a recording studio where audio around the room is to sent over ethernet. Connecting the audio out from my keyboards via an ethernet adapter to my router produces only a hum and soft, ...
schumaku
Jan 15, 2023Guru - Experienced User
What kind of adapter (make and model) and Ethernet audio interface (like AES67) are involved here?
Tunesmith
Jan 23, 2023Aspirant
Hi,
Make: K2AUDIO
Model: C5AudioP
This is a simple adapter using pins 1 and 8 for the audio signal. There are no other accessories in the chain at the moment. The quality of the audio is not critical at the moment, however, the notion of silence when not in use (or not playing) is!
My solution is obviously flawed in its simplicity. Please advise
With thanks
Glen
