Tunesmith
Jan 14, 2023Aspirant
Audio over internet GS108LP
I'm setting up a recording studio where audio around the room is to sent over ethernet. Connecting the audio out from my keyboards via an ethernet adapter to my router produces only a hum and soft, ...
Tunesmith
Jan 23, 2023Aspirant
Hi,
Make: K2AUDIO
Model: C5AudioP
This is a simple adapter using pins 1 and 8 for the audio signal. There are no other accessories in the chain at the moment. The quality of the audio is not critical at the moment, however, the notion of silence when not in use (or not playing) is!
My solution is obviously flawed in its simplicity. Please advise
With thanks
Glen
schumaku
Jan 23, 2023Guru - Experienced User
Can't see on how Ethernet (and the GS108LP switch) should be involved here. These adapters are passively connecting audio lines over an otherwise unused network cable, no Ethernet data connection involved.
- TunesmithJan 23, 2023Aspirant
Yeah, was just hoping to use the studios pre-wired system, rather than having a new cable running around the studio.
Thanks for your help tho.
Glen
