Cai
Sep 04, 2015Aspirant
Blinking led but no internet connection
Hi i have a gs108 switch and i have it connected to my modem and my pc and it works just fine so my problem is that when i connect an ethernet cable from the switch to my tv or ps3 im unable to get a...
- Sep 04, 2015
Hello Cai,
Welcome to the community!
You'll probably need a router instead of a switch, a basic modem can only give a single IP address. Since you have used the PC, it already obtained the IP address from the modem. The reason why the TV and PS3 does not get an IP is because the modem can only provide 1(one). The switches' job is to receive and send traffic so it has nothing to do with IP addressing.
I hope this helps, if you have more questions please feel free to ask.
Thanks,
JohnRo
Sep 04, 2015NETGEAR Employee Retired
Hello Cai,
Thanks,
Cai
Sep 12, 2015Aspirant
Sorry for taking so long to reply but thanks for the help i wasnt sure if i was going about it the wrong way or not but now i see have to buy a router after all
