Tobarus's avatar
Tobarus
Can I get 10gigbit between my PC and NAS with this switch?
Hi there,   I'm very intersted in purchasing the GS110MX-100NAS switch (unmanaged - I'm very new and don't need these features for home (wife and I)).   Simply put, I'll be connecting a 10gigbit ...
  • XavierLL's avatar
    Jan 20, 2018
    Hi Tobarus,
    Definetly you will get fastest speeds if you use 10Gbps connnectivity instead of 1Gbps. However you also have to take in consideration the hard drives that you are using to be able to achieve the 10Gbps :
    if you are runnnig SSD definetly you will be really close to 10Gbps but if you are running HDD the transfer speed will be limited by the type of RAID that you have configured on your NAS. However maybe you will not be able to get 10Gbps speed you definetly will notice and improvement on the transfer speed between your NAS and PC.
    Hope it helps!
    Xavier Lleixa
    NETGEAR CBU PLM
ProSupport for Business
