Sathaye's avatar
Sathaye
Can't connect desktop to INternet via Netgear GS105
I have recently got xfinity internet. My setup is as below: Cable Modem - Switch - Netgear N7000 Router                                      - Desktop To be clear: Both router and the desktop are ...
  • TheEther's avatar
    TheEther
    Sep 01, 2017
    Yes, a switch connects multiple wired devices together.
    But a router is a special type of device. You can't treat it like any other device, such as a computer. It's role in a home network is to share the Internet connection provided by the modem with multiple devices. In order for this to work, the router's WAN port needs to be directly connected to the modem.
    In fact, a router has a built in switch, composed of all its LAN ports. You can connect another switch to one of the LAN ports on the router to effectively add extra LAN ports.
    That's how this all works, so please change your setup.
ProSupport for Business
