Sathaye
Sep 01, 2017Aspirant
Can't connect desktop to INternet via Netgear GS105
I have recently got xfinity internet. My setup is as below: Cable Modem - Switch - Netgear N7000 Router - Desktop To be clear: Both router and the desktop are ...
- Sep 01, 2017
Yes, a switch connects multiple wired devices together.
But a router is a special type of device. You can't treat it like any other device, such as a computer. It's role in a home network is to share the Internet connection provided by the modem with multiple devices. In order for this to work, the router's WAN port needs to be directly connected to the modem.
In fact, a router has a built in switch, composed of all its LAN ports. You can connect another switch to one of the LAN ports on the router to effectively add extra LAN ports.
That's how this all works, so please change your setup.
TheEther
Sep 01, 2017Guru
This is not a valid setup. For the vast majority of people, the setup should always be modem->router->switch->devices. Change your setup.
Sathaye
Isn't the switch supposed to distribute network connections within all wired devices? My understanding was the internet connection coming to the switch would be split within the router and the desktop and hence should work.
- TheEtherSep 01, 2017Guru
That's how this all works, so please change your setup.- SathayeSep 01, 2017AspirantOk thanks! So looks like for my setup I will need to have a modem with atleast 2 ports. One for the switch and another for the router
- HopchenSep 02, 2017Prodigy
Hi,
I think you still misunderstand this. The router's WAN port should connect the modem. The switch and other devices should connect to the router LAN ports.
