josemose
Nov 07, 2017Follower
Can't get gs108 to work on both wifi and LAN
My house is prewired for a home network so I bought a prosafe GS108 switch and a netgear gigabit CM700 modem. I connected everything as advertised in the box. Modem to switch and switch to prewired C...
- Nov 08, 2017
Hi josemose
When is comes to wiring throughout the house, one common problem is something called Auto MDI/MDIX. I have explained here, in a thread similar to yours:
https://community.netgear.com/t5/Unmanaged-Switches/GS116-Warranty/m-p/1346459#M2078
Your issue is very likely because of this.
Also, the way to setup the network is:
"Internet connection" <--> Modem <--> Switch <--> LAN throughout the house.
But please have a read at the above thread. It think this will solve it for you.Cheers
Hopchen
Nov 08, 2017Prodigy
Hi josemose
Cheers
